Re: Stanhoist Loader on a Farmall M
Posted by Zachary Hoyt on December 08, 2012 at 16:38:11 from (50.122.173.232):
In Reply to: Re: Stanhoist Loader on a Farmall M posted by ZKlaves on December 08, 2012 at 16:09:05:
I don't know about stanhoist loaders in particular but it looks like there should be some brackets that bolt around the rear axle housing on the outer spot, just outside where the drawbar mounts. With any loader you want the pushing to come from the rear axle so you don't stress the torque tube and frame rails and crack them.
Zach
