Re: Stanhoist Loader on a Farmall M
Posted by Janicholson on December 08, 2012 at 16:42:04 from (96.24.99.126):
In Reply to: Re: Stanhoist Loader on a Farmall M posted by ZKlaves on December 08, 2012 at 16:09:05:
Yes and they are the main connection to provide push force and impact absorption. They should be closer to the axle height. a axle clamp is needed that transfers the forces to the axle. 5/8 plate, and 3/4' clamp bolts would be realistic. The bracket should be solid and cover both sides of the channels on the struts. A 3/4" grade 8 bolt (with no threads in the shear path) should be used through the bracket. Jim
