Re: SH Carb problem
Posted by wayne in mn on December 08, 2012 at 17:36:39 from (71.8.139.200):
In Reply to: SH Carb problem posted by IAtractorKid on December 08, 2012 at 17:11:17:
Drill carefully (just the brass part) gradually enlarging the hole until the cast threads begin to show. Use a #5-40 thread tap from your favorite gunsmith and clean out the threads.
You MAY be able to carefully drive a small E-Z out or screwdriver in and back the broken part out.
Be sure to blow & solvent clean ALL passages b/4 re-assembly.
Good luck.
