Posted by pete 23 on December 08, 2012 at 18:22:27 from (74.32.238.2):
In Reply to: 300 hydralics posted by JDnTN on December 08, 2012 at 18:02:06:
Seals, o-rings and gaskets are all that is possible to replace in those pumps. When the bushings wear, the gears wear into the housing and then the pump is shot. Bushings are part of the end plates. You would need to take pump apart and see if it is worth the trouble of replacing seals. Putting a speedy sleeve on a grooved shaft sounds like a good idea except that then you have a shaft that is too large to go through the bushing. Have had shafts built up where seal rides over the years. Sometimes it worked, usually didn't .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
