Re: H Charging System
Posted by John T on December 09, 2012 at 08:13:30 from (216.249.82.117):
In Reply to: H Charging System posted by Allan from PA on December 09, 2012 at 06:29:30:
So, what happend when you ran my Para 5 procedure and dead grounded the Gennys FLD post with it running??????? Did it charge then??????? If not did it charge if when still running and FLD grounded you temporarily jumped BAT and GEN/ARM together which by passes the Cutout relay function????????
If it still dont charge with both those checks and the genny has a good frame ground (does it???) and the belt is good and the rest of the wiring is correct, sounds like a bad genny. HOWEVER if it charges ONLY with FLD grounded but NOT otherwise (tells me genny is okay), the VR is bad (if its a VR) or the VR isnt well grounded,,,,,,,,or if its a cutout relay and light switch controller the light switch isnt well grounded,,,,,,,,or the wires bad from FLD on genny to light switch or FLD on a VR
John T
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par ... [Read Article]
