Posted by old on December 09, 2012 at 09:30:29 from (209.86.226.27):
In Reply to: Ignition issue posted by Dave H (MI) on December 09, 2012 at 08:45:51:
With the points open remove the wire on the side of the distributor. Turn the ignition on and hold the coil center wire close to the block then touch and pull the wire back off the side of the distributor stud. If when you do that you get a spark the insulator going in to the side of the distributor has cracked and is shorting out. Seen that happen many many times over the years so you either replace the insulator or pull the old one out and run a wire in its place then silicone the wire in place to keep water etc out
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
