Re: Farmall 560 Loud Popping Noise
Posted by Janicholson on December 09, 2012 at 14:56:23 from (96.24.99.126):
In Reply to: Re: Farmall 560 Loud Popping Noise posted by Eric in Seattle on December 09, 2012 at 10:32:44:
A compression check is done with a screw in compression gauge. If you don't have mechanics tools, you will. A good compression tester from a real tool company will be in the area of 35$ to 100+ bucks, Craftsman for 58 is pretty good.
The engine has all plugs removed.
The coil is disconnected (the distributor side of the coil is a good place to disconnect)
The Throttle is open wide
Fuel shut off is off
Fully charges good battery to spin it fast.
Put the tester in #1 cylinder (front)
Crank the engine for 5 compression strokes (you can hear it easily)
Look at the gauge and record the data on a tablet.
Do the same for each cylinder.
Use a squirt oil can and put three squirts of engine oil in each spark plug hole, spin the engine with the starter to spread the oil
Repeat the test now.
Report back to us for diagnosis.
Generally the compression should be (IIRC) 140 to 160 PSI
If uniform, (within 10 % of each other) that is also good.
Jim
