Re: Farmall 560 Loud Popping Noise
Posted by Janicholson on December 09, 2012 at 16:03:15 from (96.24.99.126):
In Reply to: Re: Farmall 560 Loud Popping Noise posted by steve alderman on December 09, 2012 at 15:48:07:
With a tapered keeper on the stem, the hammer and socket will take out keepers faster than a valve spring compressor. Use a 90 degree old fashioned monkey wrench on the rocker to depress the valve. Be sure to hold onto the pushrod, as it will be loose. Jim
