Posted by D Slater on December 09, 2012 at 17:03:47 from (184.15.16.54):
In Reply to: clutch joint hardware? posted by pete_5959 on December 09, 2012 at 15:59:41:
If a H or M type. Tapered ends of the bolts go into the transmision flange and the clutch shaft. Rubber to both sides of the middle steel piece and steel washers on the rubbers. Bolt head, washer, rubber, middle steel connector, rubber, washer, clutch shaft or flange, lock washer and nut
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
