Yes the front cover comes off along with the gov housing. But first you need to remove the steering assy where it bolts to the block as the pulley will not come off until its removed. Dont move the gov gear when you remove the gov housing unless you want to retime the dist. Do you have a bearing spliter to remove the crank pulley as its a press fit. Check the pulley as there mite be a set screw on the hub. When you get the front cover off you will see the seal and if the pulley has a grouve where the old seal has worn you will need a speedy sleeve to repair that area so the new seal has a good surface to seat on. I use a heavier seal than replacement listed i think they will last longer.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
