Re: Cub Power Unit pictures
Posted by gene bender on December 09, 2012 at 18:57:26 from (207.177.56.85):
In Reply to: Re: Cub Power Unit pictures posted by shade tree operator on December 09, 2012 at 18:19:37:
Using the same Xenith carb did they have smaller jets since it was only 69cuin. The Mag has a different front plate and they do interchange as i have done it the holes are drilled for the Cont allowing it to be rotated out from the block more than on the 113 engine.
