Re: 5088 pros / cons
Posted by Brian AB on December 10, 2012 at 08:52:56 from (173.210.251.132):
In Reply to: 5088 pros / cons posted by Reaver on December 09, 2012 at 19:10:32:
I had two 5088's when I retired from farming. One replaced a 1086. Cab size is definately larger on the 5088 with more knee room as well as cooler in hot weather with the reverse flow rad fan. You can't even compare the transmissions, the 5088 has much easier to shift trans. That same trans was upgraded to full powershift in the 7110 series. Never had any pto problems, only problem with one of the 5088's was a hi/lo transmission upgrade.
