Re: Farmall B valve issue
Posted by gene bender on December 10, 2012 at 09:51:22 from (207.177.56.85):
In Reply to: Farmall B valve issue posted by Dave H (MI) on December 10, 2012 at 09:32:33:
I would remove the rocker assy then spray the bad valve with some penetrant and gently tap it and you mite just get it to stop sticking. You can use a block of wood and a screwdriver to get it to come back up sometimes and a little tapping and spraying ect and you should get it to work.. When you get the valvesl free again replace the tappet assy and start engine you will probably need to change plugs around to get them clean and firing again. I bought on e was like yours took a while but now it starts and runs great sure smoked till the bad cycls got cleaned and firing good.
