Re: Farmall B valve issue
Posted by old on December 10, 2012 at 09:59:43 from (209.86.226.60):
In Reply to: Farmall B valve issue posted by Dave H (MI) on December 10, 2012 at 09:32:33:
Exhaust or intake valve??? If exhaust pour some ATF in the manifold and let it sit a few hours. Then take a pair of vise grips and grab the end of the valve and try to turn it a little bit. Some times that is all it takes to free one up BTDT many times. Also try to get some ATF inside the spring and on the stem so it will maybe work it way down from the top and if an intake that is about the only way to get ATF to it short of pulling the manifold off
