Re: 656 Hydro Reverse
Posted by pete 23 on December 10, 2012 at 11:25:50 from (74.32.238.2):
In Reply to: 656 Hydro Reverse posted by Heath Boe on December 09, 2012 at 19:43:44:
Do you mean the lever will not go into reverse. Sounds like that. If that is the case the adjustment may have slipped on the control valve where lever clamps onto it. If the lever goes into reverse, but tractor doesn't move, that would be a different problem. Could be sticky shuttle valve in center section, sticky relief valve, capsule in drive control valve , check valve in center. Would need more information to trouble shoot.
