Re: IH350U Hyds ?
Posted by Duner Wi on December 10, 2012 at 14:09:47 from (216.226.80.242):
In Reply to: Re: IH350U Hyds ? posted by wisbaker on December 10, 2012 at 11:50:17:
Fluid is clean and good. Leaks so bad from power steering that fluid gets replaced pretty often.
I use least expensive UTF fluid from farm store. This is thicker than some. This morning it was below freezing and when I started it the pump rattled so I let it idle for 10 minutes till fluid warmed up. The blade did seem a little slow to lift when I was moving snow but I was not concerned at the time. It acts like it is not pumping at all or very little as I can steer it. Tractor is keep indoors so it should not be water in oil.
