Does a 2-71 have a SAE sized flywheel housing? Check to see if it will fit between the M's frame rails. If the flywheel is flush with the flywheel housing, you will need a second flywheel stacked on top of the first one, to reach the input shaft. Make an adapter plate for the bell housing, a front motor mount, and have pictures posted by Friday.
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
