Re: farmall m with 2-71 detroit
Posted by mkirsch on December 11, 2012 at 05:11:52 from (64.80.110.74):
In Reply to: farmall m with 2-71 detroit posted by joe1982 on December 10, 2012 at 15:37:37:
At one time there was a kit to put a 2-something Detroit in a Farmall M, wasn't there? Good luck finding a kit after being out of production 50-60 years, though.
Sure, it's possible. All you need is enough time, $$$, a good machinist that can cut you an adapter plate, someone that can weld, and materials.
