You're compression test is FINE. Plenty of compression, and a long way from needing an overhaul. Adjusting the valves probably won't hurt, and even just using the tractor may cause the compression to even out.
The "popping" noise and power loss is probably just the cold engine SPUTTERING. These 6-cylinder engines are a bit cold blooded and will sputter some until they're warmed up, especially in cold weather. Judicious application of the choke when the engine starts to sputter will clear it up. Just give it a little blip of choke when it starts to sputter. You may have to give it a little choke every time you let the clutch out for the first few minutes after startup.
It may need carburetor work, but just give the choke idea try and see if it helps.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
