Re: Belly pump in 39 M
Posted by D Slater on December 11, 2012 at 06:39:14 from (184.15.16.54):
In Reply to: Belly pump in 39 M posted by Baelee05 on December 11, 2012 at 05:36:49:
No a 39 model would not look strange without.
Other than the cast cover already mentioned. I think a 39 model used cork like plugs in the unused holes.
If you want period correct and have a clutch housing with a casting # 8026D, DA or DB. the steel hole covers with spring clips were not used.
This post was edited by D Slater at 04:51:10 12/12/12.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
