joe1982 said: (quoted from post at 19:37:37 12/10/12) how hard is it to covert a farmall m with a regular engine to a 2-71 detroit diesel.
Well... it would be pretty easy with a set of original instructions once you were able to modify a bell housing (think machining & welding if you have the correct bell housing to get close) and a flywheel. The original package consisted of a model 2055 engine with special bell housing and flywheel. You used the ring gear from your stock flywheel and put it on the one supplied by GM. The rest was fabrication and installation.
You will also need a 2-71 with a variable speed governor.
The digital copies of poor photostats on my website (jarootfarms.com) list the parts list and part numbers etc...
If you go to http://www.jarootfarms.com/gallery there is a folder with all of the photos I took while going through my GM powered M. Unfortunately I didn't split it at the engine and therefore there are no good photographs of the bell housing or flywheel, the two important components of the formula..
I also have GM Engineering Service Bulletin instructions for a Case LA and a Farmall F20 or F30 (forget which one). The F series uses a 2-71 also but you don't need a special bell housing I don't believe. I'll see if I can get some time to digitize them and upload them to my website later this week or weekend.
With any luck I hopefully will have my M @ Lima for the 2013 RPRU next June...
This post was edited by Rootsy at 09:42:56 12/11/12 4 times.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
