Posted by IH fan on December 11, 2012 at 19:31:04 from (108.236.93.166):
In Reply to: Farmall M H upgrades posted by rustred on December 11, 2012 at 17:06:02:
rustred said: (quoted from post at 20:06:02 12/11/12) you are comparing a j d 60 to a c, well no wonder it does twice the work.the 60 is more comparable to the super m. or in the standard version the 60 is equal to the super w-6
You miss the point... the 60 is 1/2 again as big and uses the same amount of gas per hour. We pulled a 3x14' pull type plow with the 60s and a 2x14 F-H mounted with the Super C and they burned approx. the same amount of fuel per hour (not per acre), between 2 and 2 1/2 gph. Pulled a 10' tandem disk with the 60s and a 7' tandem Fast Hitch mounted with the SC and again they used approx. the same gas per hour. Are you telling me the SM will use less than a Super C??? I don't think so. The nebr. tests show the 60 using more gas than that, but we had 2 of them and neither ever used over 2 1/2 gph no matter whether you were plowing, disking, picking corn with a 2 row mounted picker, whatever. Dad always said, and I don't know because I was too young at the time, that the 60s used less than a 1940 A he had before he got the first 60. Also, the Super C used about 1/2 again (50% more per hour) the gas of the C he had before the SC.
Now I'm comparing the ones Dad owned and maybe the 60 was an extremely efficient model... don't know about the others, even though I have run some of the other 2 bangers, up to an 820. I do know I ran a 450 Farmall quite a bit and it was a real gas hog, but I thought pulled better than it should have for it's size. Same ranch had a 350D and it didn't use much fuel at all, but we never pulled it hard either like the 450G.
This post was edited by IH fan at 19:38:10 12/11/12.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
