A machine shop is exactly who you need to go to to get the shaft fixed, if you can't find a good used one anywhere and you want it "right."
They would build the shaft back up with weld, then turn it round, and mill in the splines. However, that is *VERY* labor intensive and will probably cost you several hundred dollars unless you know someone who owes you a favor.
Frankly, I would probably try the beer can fix first. That's wrapping a shim made from a cut-up beer can around the splines to take up the gap. Make sure the yoke is clamped tight, and check it periodically. The reason the splines are worn is because someone let the yoke get loose.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
