Posted by Fritz Maurer on December 12, 2012 at 05:44:56 from (216.137.138.146):
In Reply to: Re: C-113 main bearings posted by Bill Krosnicki on December 11, 2012 at 21:20:30:
I saw those bearings, and I wondered why the S/N break started so high. Rice Equipment gave me the sad news. Prior to the S/N shown, there was a different crank. The crankshaft shown on Y.T. parts list, No. 30928DBX, was a factory update with different bearings. Rice further stated the difference was wider bearings, and since the front two bearings are already as wide as the bore, I'm guessing the difference must lie in the thrust main. The crankshaft guy said that he can make the thrust main wider, "if there is enough material there to do so". He was referring to the flange just ahead of the rear main seal. So... having used C-113 mains in an F-12 before, (but never a 2405D crank before) I wanted to see how close the later bearing compared to the earlier crank. My gut feeling says "it aint gonna happen", because I'm wondering why I.H. would forge a different part no. in the crank without making a substantial change. But, how much different can it be if you drop a crank into a block, use the same caps, and oil seal retainer?
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
