Re: 656 Hydro Reverse
Posted by pete 23 on December 12, 2012 at 10:54:34 from (74.32.238.2):
In Reply to: 656 Hydro Reverse posted by Heath Boe on December 09, 2012 at 19:43:44:
OK, as long as it goes into reverse, and the linkage is actually pulling the rod up in transmission, the next thing is make sure lever is centering. It should be very close to equal distance movement in each side to side direction. You will note this moves the control valve in or out. If I could not see any reason for problem in the external linkages, the very next thing I would do is cap those two lines coming up from hydro trans housing. They are the two small quarter inch steel lines. Cap the fitting on transmisson. This will eleminate all external valves etc. You will not have control with the foot n inch pedal now so be care ful. Try that and then if it reverses ok you know problem is outside of trans. If it still does not move good in reverse problem is internal. Stuck relief valve, sticky shuttle valve, leaking steel line to relief valve, check valves etc.
