Re: LED lights and flasher problem
Posted by werksguy on December 12, 2012 at 11:21:24 from (108.8.120.157):
In Reply to: LED lights and flasher problem posted by Dean Olson on December 07, 2012 at 16:03:28:
Try wiring a resistor into the wire leading to your led flasher. When we've put led signals onmotorcycles in the past, either they flash like crazy or not at all until you add the resistor. The led draw so much less current that they don't work well with the existing flasher. I believe I have a couple laying around if you can't find them.
Good luck,
Ed
