If you have that spark as I said when you unhook and hook the wire to the coil then remove the wire from the points and make sure it is not touching any thing. If you still get that spark then it is a bad insulator going in the side of the distributor. If that is so what I do is remove the insulator then run a wire in the side of the distributor and seal that wire off with silicone then it is a fixed problem unless your wanting it to look like it was new. I have a ford 841 that has been set up that way for well over 25 years now
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
