Re: Block Heater
Posted by DeltaRed on December 12, 2012 at 18:25:10 from (67.6.219.50):
In Reply to: Block Heater posted by Bud Kaiser on December 12, 2012 at 18:04:17:
Welcome to the world of the "D-282".Most of them are that way.Some start pretty good,most dont.If the injectors are weak,dirty...The compression is down a little,the pump alittle weak....We used a tank heater.hook to the small water pump port,the other end to the head where the temp gauge goes.Use a 'T' so you can retain the temp sender.You can also use one of the 1 1/2" pipe plugs(with 3/4" sq.recess).be careful, you can break the head if its too tight/rusted.
