Re: doing cab kit in a 986, any advice?
Posted by IaGary on December 13, 2012 at 05:04:01 from (108.160.228.103):
In Reply to: doing cab kit in a 986, any advice? posted by Dave from mN on December 13, 2012 at 04:57:41:
The air coil that is on top of the cap has a foam insulation over the top to direct the air through it. That foam likes to fall apart and plug the coil.
Take the cover off the top and replace that foam if it hasn"t already been done.
Also clean out the drain lines that drain the water from the drip pan on top of the cab. These lines go down the 2 front posts of the cab.
If these are plugged they allow water to flood the new headliner and it will be junk again.
Gary
