Re: C, Super C differences?
Posted by farmallhal on December 14, 2012 at 07:00:51 from (76.4.179.245):
In Reply to: C, Super C differences? posted by cubluvn8n on December 14, 2012 at 03:30:58:
There are several differences between the two models and the s/n is located on the tool box/seat base on the right hand side but the base could of been changed at some point. The fuel tank will set up above the touch control hydraulic block about 1 1/2" on a SC while on the C there is hardly any space between the two. The brake and clutch pedals will have a curve in them on a SC while they are straight from the pivot point to the top on the C. The front grill will have a wide bar at the bottom by the hand crank hole which is significantly wider then the ones above. These are a few which should help determine what you are looking at. Good luck and hope you find what you are looking for and a Super C is a very nice useable tractor, Hal.
