Re: Gasket question
Posted by MisterT on December 14, 2012 at 08:57:38 from (216.248.71.226):
In Reply to: Gasket question posted by Darwindo on December 14, 2012 at 07:26:16:
I like to use Copper Coat, or something similar. I use it only on the side of the gasket that fits against the oil pan, valve cover, etc. That way I can remove the oil pan at a later date if needed and the gasket will not be damaged. I can use it again.
The main purpose of gasket cement is to hold the gasket in place while you install the pan, cover, etc. If you need to depend on the sealer to help seal up the gasket and stop the drips, then there are other issues which need to be addressed.
