Re: Plowing with a Super M
Posted by wisbaker on December 14, 2012 at 09:42:15 from (207.118.181.101):
In Reply to: Plowing with a Super M posted by Chester5731 on December 14, 2012 at 08:00:01:
There are many factors on what a tractor will pull,
from the ground, moisture,sod, tire condition,
ballast/weights tractor tune and what shape the plow
is in and how well it's set up to work with the
tractor. We pulled 3-14's with our Super M in ground
ranging from a sandy loam to a heavy loam. I remember
one August and I was trying to turn down wheat stubble
and get ready for wheat again. It was hotter than
usual for central Michigan- the upper 90's and it had
been dry. It was not having a good time pulling the 3-
14's. I was wondering if I should go get the 2-16's we
had for our John Deere A. Dad mentioned to me that if
I was going to work his tractor that hard maybe I
should change the oil before heading back out, I can't
remember if he told me to or I did it by myself but I
changed the oil and filter and used straight 40 weight
oil. Same conditions but the tractor temperature
dropped about 40 degrees and she handled the plow much
better. Didn't plow to much before I wore out a set of
plow points but the tractor didn't seem to be running
any hotter or heavier than when we baled the straw.
