Re: Farmall 300 transmission
Posted by Janicholson on December 14, 2012 at 14:23:14 from (199.17.6.37):
In Reply to: Re: Farmall 300 transmission posted by MoMike on December 14, 2012 at 04:32:58:
If a fork is broken, or slid on the rail, it will be possible to operate the tractor in Neutral. In most cases, the broken fork (if it is broken) will allow it to be in one gear. (any gear) if the fork is broken it could be broken in 5th. If so the engine will bog just like it would if starting in 5th. Jacking a wheel up is easiest. if it is 5th, that single wheel will spin at high RPM. if 4th not so much.
If the intermediate bearing is jammed, it will appear to be in high gear, because that is what the high gear does, is lock the two shafts together. What ever you find, it is 90% probable that the top will need to come off.
Jim
