Re: Regarding earlier post 300 transmission
Posted by D Slater on December 15, 2012 at 11:20:58 from (184.15.46.232):
In Reply to: Re: Regarding earlier post 300 transmission posted by MoMike on December 15, 2012 at 08:27:56:
I'm thinking the planet gears have to be turning in the t/a planet carrier or the tractor wouldn't roll in gear. Maybe if the t/a clutch hasn't been used in a long time it won't disengage or the linkage or other problem won't let it disengage. If the t/a planet carrier bearings got bad enough and got hot enough to kind of weld to things so that the carrier was locked, that would kill the engine if the t/a clutch won't disengage. Since I can't see the tractor i'm just throwing out some thoughts about were the problem could be.
Still thinking, scratch part of that, if the planet gear carrier is locked up and the t/a clutch won't disengage the tractor wouldn't roll in gear pulling it.
Also does this tractor still have the t/a handle and linkage hooked up. If not and the short connector rod from the main clutch operating shaft to the t/a clutch operating shaft is still there. That may be releasing the t/a clutch and letting tractor roll in gear. But if you don't have a t/a handle that will release the t/a clutch. When you let the main clutch pedal back up it engages the t/a clutch. This could kill the engine if something has the t/a clutch carrier locked from turning, or the planet carrier is locked. If you don't have a t/a handle, try operating the t/a clutch manualy and see if the engine kills.
This post was edited by D Slater at 15:07:32 12/15/12 2 times.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
