Re: Regarding earlier post 300 transmission
Posted by Janicholson on December 15, 2012 at 12:37:19 from (199.17.6.121):
In Reply to: Re: Regarding earlier post 300 transmission posted by MoMike on December 15, 2012 at 08:27:56:
IT seems to me!
The TA assembly moves in the direction of engine rotation when in direct ((handle forward). It is stationary when the TA lever is back, in reduction (unless coasting faster than moving in that gear)
If ((if))the trans is in Neutral, and the tractor rolls forward and backwards, then the issue is not in the trans output shaft, but could be in any portion that rotates with the clutch out and the trans in Neutral.
If the tractor locks up and will not move when in any gear, then the issue is in the countershaft, or the front trans input shaft bearing(not at the intermediate bearing at the 4th 5th slider).
If the engine bogs and will not drive the tractor, and bogs even in neutral, even if the ramp and rollers were toast, as in jammed and locked up, it would move with the TA released unless the TA throwout is not releasing the TA clutch from the housing.
If the tractor moves in gear, and if looking at the TA unit through the cover as suggested, the TA rotates, I have no idea how the engine could bog. Jim
Today's Featured Article - On the Road with Dave Gohl: Tractors and Farming - by Dave Gohl. I never thought I'd live to see the day, when I could call myself a farmer. What allows me to say this? Well, when our family moved to our 20 acre site near New Prague, Minnesota, I had one thought in mind. You guessed it, farm it somehow. A little history is in order. In my younger days, mom, dad and my brother made frequent visits to dad's youngest brother Pete, who took over the home farm from grandpa MIke. It was the typical set-up, milk cows, pigs & chickens. In the winter, we'd play ... [Read Article]
