Re: Found a C-153 but have some questions before buying
Posted by Machine249 on December 16, 2012 at 07:50:09 from (76.100.246.141):
In Reply to: Found a C-153 but have some questions before buying posted by The Shmunk on December 15, 2012 at 17:21:55:
If I remember correctly, you are right about the power unit fitting the C. I had a f504 and I know it would not work for that, like you said, different bell housing. What I did for a little insurance was bring the old block to the junk yard with me, but I"m sure you could make a template of your bellhousing and take measurements for the bolt holes to be sure. I know I wouldn"t want to spend the money on an engine that won"t fit unless there is a return policy from wherever you buy it. Also, you might want to think about weather or not the rest of the tractor can handle the extra engine. I would think the tractor would break traction before anything else, but just a thought. Good luck.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
