Posted by Janicholson on December 16, 2012 at 08:12:08 from (67.72.98.45):
In Reply to: 806 question posted by arky 43 on December 15, 2012 at 18:02:38:
If it is in your hand, and or available to measure, it is easy. Place the rocker on a sheet of paper and mark a circle inside the shaft hole with a sharp pencil. Without moving it, look at the center of the wear at the tip where it touches the valve stem, and make a mark on the paper at that length. Now make a mark on the paper at the center of the pushrod pocket. Using a caliper (or if none available use a 64th inch marked ruler and change to decimal inches) measure the circle diameter and divide by two to find the radius. Measure from the circle edge to each mark, and write that down. Add the circle radius found above to each. These numbers should be written as a ratio. Like 1.215:1.76 This needs to be stated so the left side is pushrod to center and valve tip to center is on the right. Divide the number one (1) by the left number, and use that result to times the right number. 1/1.215*1.76=1.449 The ratio is 1:1.449. I hope this helps some. Jim
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
