Posted by CNKS on December 16, 2012 at 10:45:44 from (216.144.104.128):
In Reply to: Re: metal ?? posted by tuckaway on December 16, 2012 at 09:57:43:
If it is a pump running off the generator belt it is homemade. However the cylinder mounted vertical on the left front sounds like it is the exhaust cylinder. The exhaust cylinder would be very large both long and in diameter with very little resemblence to a hydraulic cylinder. I have not seen an exhaust lift in about 60+ years when I was 12. If Gene Bender sees this he will clarify, he has several.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
