Re: Farmall h engine troubles
Posted by jkies on December 16, 2012 at 12:08:22 from (208.126.102.238):
In Reply to: Farmall h engine troubles posted by Andrew Psencik on December 16, 2012 at 11:50:00:
put a straight edge across the manifold to see if it is flat. sometimes you can use a double gasket to take up some warping.
