I have good fuel flow. Already checked that. Good ignition. Timing set. The tractor runs smooth and has great power when on choke. I suspect a vacuum leak because closing the choke meters the air leaking and incoming from the choke horn to the point where it is close to normal. I do realize that choking pulls more fuel but, I think this perticular issue , the tractor is getting good fuel, but manualy have to adjust the air manually.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
