Re: IH 424 Governor HELP!!
Posted by Janicholson on December 16, 2012 at 21:29:23 from (74.60.94.18):
In Reply to: IH 424 Governor HELP!! posted by Brandon Hollenbeck on December 16, 2012 at 11:41:48:
If the distributor drive is removed from the governor mounting plate you will see a slotted drive hub on the rearward side of the governor drive sprocket. If this is not turning with the engine, the cam drive (or at least the governor/distributor drive gear) is stripped. or other serious internal drive issue. The gears are directly associated with the cam drive and crankshaft pinion gear. Jim
