You can true up the manifold with some sandpaper and a FLAT surface. If you have thick piece of glass, like a table top, that works great. A welding table is also a good surface if it is clean and smooth.
Use 3M 77 spray adhesive to glue down some sandpaper on your surface. Since a manifold is pretty big you'll either need to find a big piece of sandpaper or use several sheets so you have enough space.
Rub the manifold on the paper in a figure 8 pattern. Keep checking and working until the entire mating surface of the manifold is shined up.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
