Re: Farmall h engine troubles
Posted by hattrick on December 17, 2012 at 07:31:19 from (216.57.221.66):
In Reply to: Farmall h engine troubles posted by Andrew Psencik on December 16, 2012 at 11:50:00:
While the tractor is running spray carb cleaner around the manifold and carb and if the engine picks up RPM's then you have a leak and you should be able to isolate it.
