Re: SM PTO parts
Posted by Centex Farmall on December 17, 2012 at 19:18:09 from (166.137.156.164):
In Reply to: Re: SM PTO parts posted by Dean Olson on December 17, 2012 at 18:43:16:
It"s really not hard to re-weld it. You can do a good job with it all apart. I"ve had to re-do one before. The only trick is to pay attention to indexing the lever so the operating rod is not too angular.
