You don't have to bleed anything, just work it back and forth. You may have damaged the o-ring on the filter housing and you then will suck air. Easy to tell on the hitch. Just raise it up and down a few times, leave it about half way up and then jump on it. It should be solid, if bouncy at all it has air. Since it is a single action cyl on hitch, if it does have air you will need to raise it and completely lower it a few times , AFTER, you are sure you are no longer sucking air. If o-ring is not problem, you may want to overfill the transmission about 5 gals to cover a couple of points inside where air can be drawn in . What kind of junk was in filter. Metal or just sludge. Moisture in oil in cold weather will clog filter immediately.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
