Yes it will go right on. Depending on how yours was adjusted and how this one is set weather or not you need to turn it down. Lot of pumps are turned way up beyond factory specs so no way of knowing unless you dyno it or at least read boost pressures or exhaust temp's under full load.
Today's Featured Article - The Engine Rebuild Kit - by Curtis Von Fange. I always liked engine rebuild kits. They have all the replacement parts for overhauling an engine without going to the store to get gaskets, special measuring tools, or miscellaneous parts. They come neatly packaged, clean and tidy. But it's important not to let that packaging lull you into a false sense of security. The appearance of matching sleeves, pistons, rings, and bearings can cause frustration and agony if not properly measured and installed in a workshop environment. Following c
... [Read Article]
Latest Ad:
[More Ads]
