Re: safest way to remove rear tires?
Posted by CNKS on December 18, 2012 at 17:59:23 from (216.144.104.128):
In Reply to: safest way to remove rear tires? posted by pete_5959 on December 18, 2012 at 15:35:01:
Use an engine hoist/cherry picker or whatever you want to call it. If no fluid you can then roll it around fairly easy. The tricky part is getting it off and away from the wheel, the hoist is a safety factor if you are not used to doing it.
