Posted by Larry B. 1486 on December 18, 2012 at 19:14:48 from (98.19.163.138):
In Reply to: Re: 1466 duals posted by Larry B. 1486 on December 18, 2012 at 18:50:35:
I need to correct myself on the 50 series. Most 5088's came out with 9 bolt. The 52 and 5488's used mostly 10 bolt. I have seen several 1486's and 1586's with 10 bolt.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
