Posted by jimb2 on December 18, 2012 at 19:44:23 from (174.114.182.155):
In Reply to: 464 steering posted by longear on December 18, 2012 at 19:24:23:
Hi, hand pump should work same as 454. Only difference between 454 and 464 is injection pump is turned up and may have larger rear tires. Someone could have removed the hydraulic check valve in the steering high pressure line. Without check valve the hydraulic oil will bleed off depriving steering hand pump of hydraulic oil. A bad hydraulic leak in steering pump can cause same problem.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
