Re: IH distributor rotor retainer/spring clip????
Posted by riverbend on December 19, 2012 at 06:20:39 from (74.46.179.112):
In Reply to: IH distributor rotor retainer/spring clip???? posted by mike1972chev on December 19, 2012 at 05:29:03:
i don't see anything like that in the parts book and the rotors on my tractors has always seemed loose. I just cut a strip of brass or aluminum to fit between the flat on the rotor and the distributor shaft. It should be thick enough to fit snug, but come off easily.
Greg
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
